2004 Chevy Blazer Alarm/Remote Start Wire Info
Welcome Guest :)
cyborgod
Member -
Posted: February 18, 2005 at 9:52 AM / IP Logged
I am trying to install a car alrm into my Blazer and have no idea what wires are what. Also the door lock system is driving me nuts, how to wire it so that it works with the keyless entry?
boomer_106
Silver -
Posted: February 18, 2005 at 10:59 AM / IP Logged
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | YELLOW | IGNITION SWITCH HARNESS * |
Ignition #1: | | PINK | IGNITION SWITCH HARNESS |
Ignition #2: | | WHITE | IGNITION SWITCH HARNESS |
Ignition #3: | | BROWN (+) | **** |
Accessory: | | ORANGE | IGNITION SWITCH HARNESS |
Brake Light: | | WHITE (+) | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | WHITE ac | Green plug at PCM (passenger fender) |
Parking Lights: | | BROWN (+) | DRIVER'S KICK PANEL |
Headlights: | | | |
Diesel Glow Plug: | | N/A | |
Clutch Bypass Wire: | | N/A | |
Notes: | | * This Vehicle Is Equipped With GM's PASSLOCK II Anti-Theft System; Use Universal Alarm Bypass Module or Vehicle Specific Bypass DTI #23545 ****All DesignTech remote starters except the 2xx22 have an ignition 3 output - it is the WHITE/ black in the 'control harness.' This wire will be used to control the bypass module, if needed. This wire will require a relay for the Brown (ACC)wire. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | RED | IGNITION SWITCH HARNESS |
OEM Alarm Disarm: | | LT. GREEN (-) | BCM in purple plug (Center console, below radio) |
Dome Lights/Superv: | | | |
OEM Horn: | | Black (-) | STEERING COLUMN HARNESS |
Power Lock: | | Lt.blue (+) | BCM Brown plug Center console, below radio) |
Power Unlock: | | White (+) | BCM Brown plug Center console, below radio) |
Trunk Release: | | Black (-) | Switch |
Alarm Input Wire: | | | |
Notes: | | *This vehicle uses an extremely complex lock/unlock circuit. To Lock/Unlock, we recommend use of the 23561 Door Lock Interface module, available through DesignTechs sales department at 800-337-4468 . Alternatively, you can wire inside each door for reverse polarity door locks. The 23561 module is easier to install, less expensive, and requires less wiring than the reverse polarity/relay method. Motor Wires, should you choose the reverse polarity method, are Gray for Lock and Tan for unlock. SOME of these vehicles have a switch on the right rear panel which can lock/unlock all doors as a positive trigger system. If so equipped, the wires are Lt Blue for lock and White for Unlock. Connection of the locks without the module is not supported. |
Sunday, April 19, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
