1992 mazda 929 door locks
rock1
Copper - Posts: 120
Posted: April 06, 2005 at 12:59 AM / IP Logged
where is the unlock wire for the 1992 mazda 929. the wiring chart
does not show anything for that.
thepencil
Gold - Posts: 1,526
Posted: April 06, 2005 at 9:27 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - MAZDA / 929 / 1992 / Remote Start
12volts gray    +   steering column
Starter WHITE/ red    +   steering column
Second Starter
Ignition BLACK/ white    +   steering column
Second Ignition
Third Ignition
Accessory BLACK/ red    +   steering column
Second Accessory
Keysense
Power Lock gray/black    -   relay above gas pedal
Power Unlock blue/white    -   black plug, dr kick
Notes: Blue/white at the relay DOES NOT DISARM FACTORY SECURITY! Remove silver module in drivers kick panel. Reach into recess, pull out harnesses. Two blue/whites in black plug. Test the one which is one pin from the corner, shows (-) pulse when door unlocked with key. Very short pulse disarms without unlocking. Remote starting will trigger factory security. Use a 528T pulse timer at minimum duration to disarm w/o unlock.
Lock Motor
Unlock Motor
Parking Lights+ BROWN / white      several at fusebox
Parking Lights- RED / yellow      steering column
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger blue    -   fusebox in dr. kick
Dome Supervision
Trunk/Hatch Pin GREEN/ red    -   at CPU high left kick
Hood Pin blue/red    -   at CPU high left kick
Trunk/Hatch Release grn/yel, BROWN / white    +   cancel switch, switch
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm blue/white    -   dr. kick behind mod.
Disarm No Unlock
Tachometer RED / blue   AC   coil
Wait to start
Brake Wire WHITE/ green    +   switch or running brd.
Parking Brake
Horn Trigger GREEN/ red    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.1992 mazda 929 door locks -- posted image.
rock1
Copper - Posts: 120
Posted: April 06, 2005 at 10:02 AM / IP Logged
drives kick panel is that near the fusebox
rock1
Copper - Posts: 120
Posted: April 13, 2005 at 3:34 PM / IP Logged
I cant find the Unlock blue/white wire,
there is a more then one blue/white wire.
Do anyone have a 929 with a keyless aftermarket setup for an alarm?
