2006 Honda Pilot Alarm/Remote Start Wiring
blulitez
Posted: February 06, 2006 at 9:03 PM / IP Logged
Hi, can anyone here help me with a wiring diagram for a 2006 Honda Pilot EX-L. I'm tryn' to install a clifford rsx 3.5 alarm w/remote start...
Any help would be greatly appreciated
My e-mail address is: import_2nr@msn.com
Thanks in advance2006 Honda Pilot Alarm/Remote Start Wiring -- posted image.
Montrealler
Copper - Posts: 155
Posted: February 06, 2006 at 10:22 PM / IP Logged
Up to what I know they are the same in 2006 then in 2005. There is a link... Badly this one will expire in 48 hours ...
http://www.autostart.ca/pageweb.nsf/C211375925D8B09985256C2100588022/CCE69562718D362A8525710E0016DE43
infinkc
Copper - Posts: 438
Posted: February 06, 2006 at 11:19 PM / IP Logged
from the above post
+12 Volts White Ignition Harness +
Ignition BLACK / YELLOW Ignition Harness +
Accessory Yellow Ignition Harness +
Starter BLACK/ White Ignition Harness +
Tachometer Blue At Diagnostic Connector Under Hood Ac
Lock Blue/Green Passenger's Side Fusebox -
Unlock BLACK/ Red Passenger's Side Fusebox -
Horn GREEN/ Blue At Switch -
Parking Brake GREEN/ Purple At Switch -
Doorpin - ****See Notes N/A
Hoodpin Yellow ***See Notes -
Arm Blue/Green Passenger's Side Fusebox -
Disarm BLACK/ Red Passenger's Side Fusebox -
Brakeswitch WHITE/ Black At Break Pedal Switch +
Parking Lights RED / Black At Fusebox +
Trunk Pin Orange *****See Notes -
SECURITY -OEM ALARM -TRANSPONDER
Comment/ Commentaire
* Vehicle is equipped with a Transponder anti-theft system and an OEM alarm.
** Key sense: Blue/ Black (-), May need to be powered during remote starts to avoid problems with the dome light,
in green connector at steering column.
*** At driver multiplex unit, attached to the driver fuse box. Green connector 22 pin , facing firewall
**** Door triger:
Driver side door trigger, in driver side fuse box. 10 pin plug
LF: GREEN/ orange
LR: Green Black
Passenger side door trigger, in passenger side fuse box 20 pin plug
RF: WHITE/ Orange
RR Green /White
*****Trunk pin is foud at driver multiplex unit, attached to the driver fuse box. Green connector 22 pin , facing firewall
Tach could also be found at driver fuse box: blue 2 silver dot.
When using A wired bypass unit the Ignition wire at the transponder receiver is Red White and the data wire is red blue.
There are 10 types of people in the world, ones that understand binary and ones that dont.
