passing 1/0 thru 2001 Maxima Firewall?
t0mmyr
Copper - Posts: 55
Posted: March 28, 2006 at 11:59 AM / IP Logged
I'm having difficulty finding a good hole to run 1/0 cable from the engine to my trunk, i couldn't find a good spot and all the locations where i could peel the rubber from and hit firewall look dangerous to drill through to the other side from.  i'd really like to run the cable down the middle of the car under the carpet so i can run rcas and speaker cables along the sides
can somone please point out a good place to drill or a good factory gromet? i couldn't find the main wireharness either on the drivers side!
doibuy
Copper - Posts: 177
Posted: March 29, 2006 at 5:33 PM / IP Logged
If it is an automatic, drill your hole where the clutch master cylinder would normally go
austincustoms
Copper - Posts: 232
Posted: March 30, 2006 at 7:08 PM / IP Logged
what about the throttle cable hole? or maybe somewhere around the steering?
slab42
Copper - Posts: 56
Posted: March 30, 2006 at 7:10 PM / IP Logged
run it under the car.  so much easier, and no bulge in your carpet!  just find a good route (with brake lines works)  it is usually easier on a truck or car with a real frame, but it can be done on uni body cars.  then drill a hole under the rear seat, or in the trunk, and use a good grommit.
78mercman
Member - Posts: 6
Posted: April 25, 2006 at 10:04 PM / IP Logged
if you're worried about a bulge in the carpet, run all your wires under your door trim. run your power wire under whichever side of the car your battery's on, and run your rca's and other wires on the other side. if you run your power wires and sound wires that close together, you'll hear interference in your speakers.
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
