1995 camaro
camar92
Posted: January 11, 2003 at 9:29 PM / IP Logged
can anyone give me the diagram to the light switch, defroster rear, dimmer switch, brights light,
check website for details.
Platinum - Posts: 12,488
Posted: January 11, 2003 at 11:27 PM / IP Logged
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|        ACCESSORY|orange              |+  |right of drivers kick       |
|       POWER LOCK|*1                  |5wi|*1                          |
|     POWER UNLOCK|*1                  |5wi|*1                          |
|       LOCK MOTOR|gray                |   |keyless entry module *2     |
|     UNLOCK MOTOR|tan                 |   |keyless entry module *2     |
|    DISARM DEFEAT|tan                 |   |keyless entry module *2     |
| PARKING LIGHTS +|brown               |   |drivers kick panel          |
|       HEADLIGHTS|yellow              |+  |headlight switch            |
|     DOOR TRIGGER|gray *3             |-  |behind left rear speaker    |
|  TRUNK/HATCH PIN|tied in with door   |   |                            |
|TRNK/HTCH RELEASE|BLACK/ white         |+  |low in the passengers kick  |
|       TACHOMETER|white or RED / black  |   |coil/dist. assembly *4      |
|      SPEED SENSE|GREEN / WHITE         |4  |rear of instrument cluster  |
|       BRAKE WIRE|lt. blue or yellow  |+  |at brake switch             |
|     HORN TRIGGER|black               |-  |black conn. st. column      |
|           WIPERS|green or gray       |+  |black conn. st. column      |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |drivers door motor          |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |drivers door harness        |
This is as much as I have as far as some of the wire colors. Sorry, no schematics or anything.
