| 12volts | lt. blue/red (20A) | + | ignition harness |
| Starter | pink/orange | + | ignition harness |
| Second Starter | PURPLE / brown | - | ignition harness |
| Notes: The second starter wire is negative trigger thru a 150 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information. |
| Ignition | pink/lt. green | + | ignition harness |
| Second Ignition | N/A | | |
| Third Ignition | N/A | | |
| Accessory | same as second starter wire | - | ignition harness |
| Notes: The accessory wire is negative trigger thru a 560 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information. |
| Second Accessory | N/A | | |
| Keysense | N/A | | |
| Power Lock | PURPLE / dk. green | - | driver door module in door |
| Notes: Lock is negative trigger thru a 330 ohm resistor. Unlock is negative trigger thru a 100 ohm resistor. MUST use relays.Can also use the trigger wires for the door lock relays found at the instrument cluster, conn. 2. Lock is lt. GREEN/ dk. green in pin 5. Driver door unlock is tan/lt. green in pin 6. Passenger door unlock is PURPLE / lt. green in pin 7. |
| Power Unlock | same as power lock wire | | |
| Lock Motor | lt. GREEN/ lt. blue | 5wi | plug above fuses, pin 36 |
| Unlock Motor | lt. GREEN/ dk. green | 5wi | plug above fuses, pin 35 |
| Parking Lights+ | do not use, relay rests at gnd | | |
| Parking Lights- | (CAN data bus) | | |
| Hazards | WHITE/ dk. blue to WHITE/ tan | - | SCM, 16 pin plug, pin 16 |
| Notes: The SCM (Steering Column Module) is in the steering column. |
| Turn Signal(L) | use hazards wire | | |
| Turn Signal(R) | use hazards wire | | |
| Reverse Light | WHITE/ lt. green | + | IPM , conn. 2, pin 2 |
| Notes: The IPM (Integrated Power Module) is on the driver fender, behind the battery. |
| Door Trigger | see notes | - | each kick or cluster, conn. 3 |
| Notes: The LF door is purple in pin 6. The RF door is PURPLE / white in pin 7. The LR door is PURPLE / gray in pin 4. The RR door is purple / YELLOW in pin 5. Use all four wires and diode isolate each wire from each other and the control module. Refer to DirectFax 1076 for wiring information. |
| Dome Supervision | yellow/orange | - | any light or cluster, conn 2, pin 12 |
| Trunk/Hatch Pin | pur/org and pur/brn (glass) | - | DKP or cluster, conn. 3, pins 3, 2 |
| Hood Pin | N/A | | |
| Trunk/Hatch Release | ORANGE / purple | - | DKP or cluster, conn. 3, pin 8 |
| Notes: Meter this wire while opening the rear glass from the switch on the rear hatch.The hatch release motor wire is ORANGE / gray (5wi) at the plug above the fuses, pin 25. |
| Power Sliding Door | N/A | | |
| Factory Alarm Arm | factory remote only | | |
| Factory Alarm Disarm | factory remote only | | |
| Disarm No Unlock | with ignition and Sentry Key | | |
| Tachometer | NOT RED / tan or dk. grn/lt. grn | ac | any ignition coil or fuel injector |
| Wait to start | N/A | | |
| Brake Wire | WHITE/ tan | + | brake pedal switch |
| Parking Brake | dk. GREEN / WHITE | - | switch or cluster, conn. 1, pin 16 |
| Horn Trigger | dk. GREEN/ orange | + | horn or IPM, conn. 2, pin 35 |
| Memory Seat 1 | lt. GREEN/ orange | - | driver door module in door |
| Notes: The memory seats are negative trigger thru resistors. The resistor values are not known at this time. Cut the wire and meter it while pressing the memory seat buttons. |
| Memory Seat 2 | same as memory seat 1 wire | - | |
| Memory Seat 3 | N/A | - | |
