2005 Chevrolet Suburban, Steering Wheel Stereo Wiring?
fat42
Posted: November 26, 2006 at 4:47 PM / IP Logged
Hi..
Does anyone have the stereo wiring for a Suburban??  I particularly need the wiring colours for the steering wheel controls...
Cheers!!
Pete
Once You've Had Fat, You'll Never Go Back!
Platinum - Posts: 13,726
Posted: November 26, 2006 at 5:20 PM / IP Logged
Don't know the wiring for it   but this page may offer some helpful products
http://www.pac-audio.com/products/productsCatagory.asp?mmSearch=Steering%20Wheel%20Interface
master5
Silver - Posts: 1,123
Posted: November 26, 2006 at 5:53 PM / IP Logged
Here are the basic color codes. For the steering wheel controls the link in the last reply makes the adaptors which come with the color codes for that..if you just need the codes call the companys tech support and they might give it to you if you can't find it elsewhere...good luck
Radio 12v  orange   +   radio harness
Radio Ground  BLACK/ white   -   radio harness
Radio Acc.  (Class 2 Serial Data)*
Radio Illumination  BROWN / white (dimmer)   +   radio harness
Factory Amp Turn-on  pink   +   radio harness
Power Antenna  dk. green   +   radio harness
LF Speaker +/-  tan - gray   +,-  radio harness
RF Speaker +/-  lt. green - dk. green   +,-  radio harness
LR Speaker +/-  brown - yellow   +,-  radio harness
RR Speaker +/-  dk. blue - lt. blue   +,-  radio harness
Notes: If equipped, the amplifier is under the center console.
* class 2 serial data...if you are replacing the head unit you need to run your own accy wire but I reccomend the proper interface to retain chime, RAP and other features..you can use the scosche DCGM09 or similar..if you have onstar you need the onstar interface to retain it also available from scosche and others.
Wednesday, April 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
