2007 honda pilot alarm/remote start
thinhvyfta
Posted: December 18, 2006 at 9:04 PM / IP Logged
can someone post wiring for 07 pilot, i like to install a remote starter, but don't have wiring diagram,
thank you
KarTuneMan
Platinum - Posts: 7,056
Posted: January 01, 2007 at 8:55 AM / IP Logged
06 and 07 are the same
PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 PLEASE NOTE: This vehicle is equipped with TRANSPONDER chips in the ignition keys. This system must be bypassed for Remote Starter installation. A keyless bypass module may be available, contact your distributor to find out. If one of these modules is not available to you, see the appropriate security diagram for bypass instructions.
 12 VOLTS White Ignition switch harness   +
 IGNITION BLACK / YELLOW Ignition switch harness   +
 ACCESSORY Yellow Ignition switch harness   +
 STARTER BLACK/ white Ignition switch harness   +
 KEY SENSE Blue/black Ignition harness   -
 TACH SIGNAL Blue/silver dots 1-pin plug near master brake cylinder   AC
 LOCK BLACK/ orange Top center plug on pass. Side fusebox   -
 UNLOCK Blue/orange Top center plug on pass. Side fusebox   -
 DOORPIN BLACK/ white Behind on/off switch on right of st. column   -
 HOODPIN Yellow At hood latch in engine compartment   -
 TRUNK PIN Blue/black Green 22-pin plug on driver's fusebox   -
 FACTORY ARM Blue/white or Blue/green Pin-7 on top center plug in pass. fusebox   -
 This wire will also lock the doors. Models without a passenger side door keyhole will not have a wire in position 7 of the connector. You can put a wire into the plug to operate the alarm.
 FACTORY DISARM BLACK/ red Pin-3 on top center plug in pass. fusebox   -
 This wire will also unlock the doors with a double pulse. Models without a passenger side door keyhole will not have a wire in position 3 of the connector. You can put a wire into the plug to operate the alarm.
 BRAKESWITCH WHITE/ black At switch above brake pedal   +
 PARKLIGHTS RED / black In driver's kickpanel   +
 PARKLIGHTS (-) RED / yellow At the light switch harness   -
 HAND BRAKE GREEN/ red Green 22-pin plug on driver's fusebox   -
 HORN Lt.GREEN/ blue At steering column   -
 HEADLIGHTS Green At light switch harness   -
 REVERSE LIGHTS GREEN/ black Under pass. side running board   +
 VSS WIRE Blue/white Green 22-pin plug on driver's fusebox   AC
 TRANSPONDER IGNITION Yellow/black At 7-pin plug on Ignition switch assembly   +
 TRANSPONDER DATA 1 Pin-2 At 7-Pin connector   DATA
 TRANSPONDER GROUND BROWN / yellow Pin-1 at 7-Pin connector   -
