92 mustang 6 speaker wiring
smolderingashes
Posted: March 29, 2007 at 7:00 PM / IP Logged
i found out the door speaker and rear speaker wire colors on here. i need help on the 2 speakers in the dash.
there are the two female plugs for the radio, then there are 2 male plugs (the 4 plugs look like they fit together). there is also 2 grey femles plugs (8 pronged i think), and a bunch of wires that someone had put wire connectors on.
KarTuneMan
Platinum - Posts: 7,056
Posted: March 31, 2007 at 11:58 PM / IP Logged
+12V DC Battery(Constant)Lt.GREEN/ YELLOW  15 amp Fuse panel
Switched AccessoryYellow/black  11 15 amp Fuse panel
Ground Red Could change to BLACK/ light green
Illumination Lt.blue/red Also ORANGE / black
92 mustang 6 speaker wiring -- posted image. AMPLIFIER OUTPUTS
Wire FunctionColorNoteFuse #SizeLocation
12V DC BatteryYellow/black  11 15 amp Fuse panel
Left Front Mid + ORANGE / lt.green
Left Front Mid - Lt.blue/white
Right Front Mid + WHITE/ lt.green
Right Front Mid - Dk.GREEN/ orange
Left Rear Mid + Pink/lt.green
Left Rear Mid - Tan / YELLOW Or pink/light blue
Right Rear Mid + Pink/lt.blue
Right Rear Mid - BROWN / pink Or Dark GREEN/ orange
92 mustang 6 speaker wiring -- posted image. AT SPEAKERS
Left Front Tweeter + ORANGE / lt.green
Left Front Tweeter - Lt.blue/white
Right Front Tweeter + WHITE/ lt.green
Right Front Tweeter - Dk.GREEN/ orange
92 mustang 6 speaker wiring -- posted image.  Available Notes
Notes
Audio outputs (line level) from the radio going to the amplifier are as follows: radio pin-out section C281, pin 1 (light green) to amplifier pin 5 in section C282; radio pin 2 (BLACK/ white) to amplifier pin 2; radio pin 3 (light blue/black) to amplifier pin 6; radio pin 5 (WHITE/ red) to amplifier pin 4, and radio pin 7 (PURPLE / white) to amplifier pin 3.
DOES THIS HELP?
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
