2007 honda odyssey vss wire
convoy2337
Posted: April 20, 2007 at 12:31 PM / IP Logged
Just wanted to post a thread in regards to a 2007 honda odyssey vss wire. After hours of searching I finally got a schematic from Honda. The VSS wire is at the pcm but not in the location listed everywhere else i looked. The wire you need it in position B38 and is BLUE. Hope this helps someone.
KarTuneMan
Platinum - Posts: 7,056
Posted: April 20, 2007 at 3:57 PM / IP Logged
VSS WIRE Orange At cruise module behind center console   AC
 Also found Blue/white at the PCM on the driver's side fender under the hood.
This info is NOT correct ??
