2014 tundra oem backup cam issue
desh187
Copper - Posts: 310
Posted: May 09, 2014 at 2:29 PM / IP Logged
Installed a JVC DDin Nav unit to a 2014 Toyota Tundra with stock backup camera.
Stock camera works on 6volts power supply so i used a voltage regulator 7906 to the 24 pin camera connector which has black-cam power,gray-cam ground,red- Positive video signal and white negative signal all color taken from vehicle schematics
I still cannot get stock camera to turn on.Aftermarket camera works fine and stock camera comes on with stock deck.Customer wants stock camera to work.
Any ideas will be very much appreciated.Thanks
desh187
Copper - Posts: 310
Posted: July 04, 2014 at 11:42 PM / IP Logged
Issue resolved,Black cam power wire gets power from reverse wire which turns on the oem camera.
Thursday, May 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
