2016 dodge ram 2500hd, nextrac tracking
liljim63
Posted: October 26, 2016 at 2:29 PM / IP Logged Link to Post Post Reply Quote liljim63
I'm looking to install a nextrac tracking device. It's a 3 wire system. It has ground, 12v constant, and a True 12v ignition wire. I can't find a 12v ignition wire to tap into that doesn't drop below 10V at start up.
wisco_install91
Posted: December 05, 2016 at 10:37 PM / IP Logged Link to Post Post Reply Quote wisco_install91
You could use a relay. Connect pin 86 to your ignition wire, connect pin 85 to ground, connect pin 30 to your 12v constant wire and connect pin 87 to the 12v ignition input of your tracking device.
Tell me again about your 5,000 watt amp you got for $99.00
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
