Floor Mount DVD
DjIQ
Copper - Posts: 107
Posted: June 16, 2003 at 11:02 AM / IP Logged
Whats the best method for mounting accessories in the floor? what kind of screws to use? should i jack up the car and bolt the screws underneath?
Powerslave0
Copper - Posts: 116
Posted: June 18, 2003 at 1:29 PM / IP Logged
Floor bolting is ok, just be prepared for skips and all that when you hit bumps.
Usually, just drill the holes through the floor, and use METAL screws. I mount CD changers this way, I mounted an AMP and CD changer on my rear seats in the trunk, just drilled through the metal, and screwed them in, no problems.
I had a GEO TRACKER, I just pulled the seat out, mounted the changer, drilled the holes though at the brackets, screwed it down, put the seat back in. . .
