getting rid of FM modulator, replace with?
ewg751
Posted: April 05, 2004 at 2:03 PM / IP Logged
dear memebers on the forum,
it is been a while i have post here...and now i need your guy's help again. first of all, really need to thank jeff for helping the best he can, he is really a cool guy.
back on topic. I have been using FM modulator to get sounds from my DVD player. However, the quality is not as good as directly connecting the wires into the speakers. so my question is, if i get rid of the FM mod, what can i do to produce good quality sound from my dvd unit into my speakers. (i still have my stock radio unit) Do i need to get a brain? if so, what kind?
THANK YOU YOU GUYS!!
Platinum - Posts: 12,488
Posted: April 06, 2004 at 1:50 AM / IP Logged
As far as I know the systems that add onto the OEM radio's are only able to piggy back the FM signal and playback through the OEM stereo. If you want to directly feed into the speaker's, you would need to get an aftermarket system with an AUX input for the audio output's of the DVD player.
Aside from this there may be some companies that make an interface module that will directly feed into the OEM amplifier or OEM headunit, but it will be limited to the make & model of the vehicle that you have. PAC makes alot os interface products for Chevy trucks and  car's.
raydawg357
Silver - Posts: 769
Posted: April 07, 2004 at 10:05 AM / IP Logged
You can also try a different brand of fm modulator.  I've noticed that some of the cheaper ones produce engine hum.  I've even used a ground loop isolater to elliminate noise.
Do it right the first time
jimmysolo2001
Member - Posts: 13
Posted: April 09, 2004 at 11:47 PM / IP Logged
You can try a digital FM modulator it work very good
customsuburb
Gold - Posts: 1,813
Posted: April 10, 2004 at 11:53 AM / IP Logged
What car or truck do you have?
Agdodge
Posted: April 15, 2004 at 4:25 PM / IP Logged
Look at http://www.pie.net they make cables for pretty much all makes and models that plug into the AUX / CD Changer port of your radio.
I'm using it on my 02 Durango and it is 100 times better than the FM modulator I had before.
Good luck.
AGDodge
Jay T
Copper - Posts: 169
Posted: April 15, 2004 at 9:42 PM / IP Logged
I purchased a kenwood Aux / cd changer plug that accepts RCA's but its for Kenwoods obviously.   I beleive that the above link (pie.net) has ones that fit into factory cd changer inputs.
Nocturnal
Copper - Posts: 85
Posted: April 18, 2004 at 10:48 PM / IP Logged
I am with jim's idea of the digital modulator.  The sound from mine is great....
beyondamfm
Copper - Posts: 105
Posted: April 19, 2004 at 9:52 AM / IP Logged
As they all metioned above you are wanted to keep your oem radio, just invest in a digital modulator it will be a noticable difference.
The Clear Bra Guy
KCs premiere paint protection guru
