avic n1 vcd
zadam123
Member - Posts: 27
Posted: June 20, 2004 at 7:01 PM / IP Logged
I was reading on the website that the avic n1 can play video cds, I made a vcd but when it put it in the radio it said non playable disc. Does it play them or not? anyone have this problem?
thanks
adam
AutoSolutions
Posted: June 24, 2004 at 8:19 PM / IP Logged
I had that problem, but it does not play vcds, spoke to pioneer about it- it does play burn dvd's   :)
area52
Posted: July 10, 2004 at 1:25 AM / IP Logged
I tested dvd-r and dvd-r and both worked.
LudeBoi
Copper - Posts: 81
Posted: July 13, 2004 at 12:21 AM / IP Logged
what program did you use? you are probably burning it incorrectly...
zadam123
Member - Posts: 27
Posted: July 13, 2004 at 5:12 AM / IP Logged
I used my dvd.  I know i did it right cause i played the vcd in my other car and works fine.
adam
kcmedic
Member - Posts: 27
Posted: July 17, 2004 at 1:16 PM / IP Logged
LudeBoi- Does that mean you've been able to play VCDs in your N1?
carmvon
Posted: September 09, 2004 at 7:21 PM / IP Logged
Ok guys i have a lil info. This player does play vcds but they dont work if burned onto a cd-r they definitely work using dvd-r and dvd-rw. A friend of mine that works at pioneer said he heard that if you use a cdrw that it may work also I cant try this method right now cause my burner is fried. =( if anyone can try this and let us know it would greatly appreciated. I also included a alternate burn method for cd-r and cd-rw if it doesnt work
First, make a normal MPEG-2 file (for example with TMPGEnc using its SVCD-templates). You normally only have to add this file to VCDEasy in order to create a SVCD 1.0... But this is exactly what some home players can't play... The idea is to use the MPEG-tools in TMPGEnc to multiplex this MPEG2 file for SVCD (with a "MPEG-2 Super VideoCD [VBR]" header) again but this time just with a different header (the "MPEG-1 VideoCD [non standard]" header). If the multiplexing is done right , VCDEasy will recognize the file as a MPEG-1 video file, you then will be able to create a VCD 2.0 (with a MPEG2 file in fact... hoping your player will be able to play it...). Note that PowerDVD will recognize this file as MPEG-2 file (while playing, do a right click on the video, choose "Show information" in the pop-up menu )
Also, not all home players can play VCD's like this. But mine (JVC XV-521BK) does, while it can not play SVCDs.
Start TMPGEnc, and close the wizard if there is one.
Select "MPEG Tools" in the "Files" menu.
avic n1 vcd -- posted image.
Select the "Multiplex" tabbed page
Click on "Add" to open your file-browser and then select your MPEG2 file
You should then have something like this
You can see here the video stream, and the audio stream
Note that "MPEG-2 Program(VBR)" is selected in the "Type" drop down list. This is the original header of this file... And this is what we have to change...
Choose "MPEG-1 Video-CD (non-standard)" in this "Type" drop down list
Be sure to have "MPEG-1 Video-CD (non-standard)" selected
Click "Browse" to set the output file name
Hit "Run"... and wait!
That's it! You have now created a fake VCD MPEG-1 file from a SVCD MPEG-2 file.
With VCDEasy's "MPEG Tools" page:
Before
After
Now you can proceed as writen in the " How to make your first VideoCD" guide.
If you are lucky you can play VCD with the quality of a SVCD, which is normaly much better.
Note that, during authoring, you can use the VCD2.0 features, but not the SVCD ones (for example: selectable subtitles & audio).
For some home DVD players, you should use "MPEG-1 Video-CD" instead of "MPEG-1 Video-CD (non-standard)" as header... even if this "VCD-Header trick" is something "non-standard" !
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
