Headphones not working?
tiburon337
Posted: August 11, 2004 at 1:18 PM / IP Logged
A customer brought in his new Escalade so I could see why his headphones don't work. The brand is XO Vision. Shouldn't the headphones work as soon as you turn them on. Also, shouldn't you be able to listen to the radio, and listen to the movie or whatever on the headphones. Thanks in advance for any help!!!!!!!
raydawg357
Silver - Posts: 769
Posted: August 12, 2004 at 10:04 AM / IP Logged
The unit should contain headphone amp,  make sure the antenna (usually a small ga. wire) is ran correctly.  Some units also come with up to three different channels, make sure the headphones are on the correct frequency.  You should only be able to listen to what is on the screen,  you won't receive any music stations.
Do it right the first time
Tuesday, September 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
