New tv's installed but have engine noise
zownes
Member - Posts: 14
Posted: March 26, 2005 at 11:43 AM / IP Logged
Have a 2004 gmc denali and just recently had 2 Farenheit 7"tv's on the visor and 2 Saav headrest installed and when i turn on the truck you can hear the engine noise thru the speakers when accelerating .Do they make something to filter this or did they not properly ground this?Also when exiting my dome lights will not turn on unless i manually do it.
amb4life
Copper - Posts: 87
Posted: March 26, 2005 at 5:13 PM / IP Logged
I was having the same problem with a pair of BOSS flipdowns. I tried regrounding which helps a ton. There still was a little noise after that. I really couldnt figureout what is was so i decided to try a higer quality monitor from JVC. They work perfectly fine with no engine noise after the switch. Hope this helps a little.
Eclipse 5435
US Amps Merlin MD2 x 2
US Amps Merlin MD42
Kicker Solo X 18"
MB Quart QSD216 x 2
zownes
Member - Posts: 14
Posted: March 26, 2005 at 7:14 PM / IP Logged
Thanks for the input
Chad7n7
Silver - Posts: 408
Posted: March 26, 2005 at 10:12 PM / IP Logged
sounds like a grounding issue.
DaRKCrow
Member - Posts: 9
Posted: March 30, 2005 at 12:05 PM / IP Logged
Please clearify if you get engine noise on the screen or comming out of the speaker?
If it's comming from the speaker, reground will help or spend alittle money and buy the Audiovox FM modulator kit with filter.  That unit seems to be the best sound quality on the market.
zownes
Member - Posts: 14
Posted: April 06, 2005 at 12:23 AM / IP Logged
will do thanks
