in-dash monitor wiring?
civic_sir
Posted: May 03, 2005 at 5:04 PM / IP Logged
hello everyone, welcome to stupid question time!
i just purchased a innovatek in-703L in-dash monitor for my 1999 civic sir coupe. too bad the instructions for wiring are notthat great. i was curious if anyone could help me out with the wiring on this matter, i am supplying ALL the info i can give everyone about the wires.
power supply 12v (has inline fuse)= RED
accumulator 12v (clock) yellow (which i assume is the same as the yellow for a cd player "memory")
black ground wire
mint green wire
the instructions say "ground with black & green wire"
so. . . does that mean to ground both the green & black in the same location? what about the ebrake line???
are there any suggestions on the best location for the power wire & the accumulator wire? thank you in advance
Platinum - Posts: 12,488
Posted: May 03, 2005 at 11:57 PM / IP Logged
The green wire I will assume is your (-) input for the parking brake wire so that if this wire doesn't see a ground, the video will not work. To grab the constant wire ( YELLOW ) go to the BLUE/WHITE ( or WHITE/ BLUE, I can't remember but make sure that you check with a DMM or light tester ) wire on the wiring harness on the radio and the IGNITION wire you can grab the radio and the color is YELLOW/RED
Captanham
Silver - Posts: 365
Posted: May 04, 2005 at 11:03 PM / IP Logged
it's blue/white out of the radio
Bad Boys Customs
    audio - video - security
If you use it. Suport it. Donate to the 12 volt!
auex
Platinum - Posts: 5,041
Posted: May 05, 2005 at 9:30 AM / IP Logged
I say constant is WHITE/ blue with 2 silver tracers.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
