Eclipse BEC104
Lizardking
Copper - Posts: 184
Posted: May 08, 2005 at 5:04 PM / IP Logged
Made a big boo boo!!  I installed my back up camara today and when running my cable which is a two piece cable the connectors got stuck on something. I tried forever it seemed to work it loose with no success. Anyway I ended up cutting the cable and soldered it back together was this okay to do? I never had to solder something like that before and I'm really good with soldering but not sure if you can solder video cable..
Wires:   Black, Red, Yellow and white (which was the outer insulation wire).
Eclipse "Approaching Perfection"
Lizardking
Copper - Posts: 184
Posted: May 08, 2005 at 9:51 PM / IP Logged
I found out it doesn't matter at least I hope!!
Ravendarat
Platinum - Posts: 2,806
Posted: May 08, 2005 at 10:53 PM / IP Logged
As long as it works and you arent getting any goofy interference than I guess you are good to go
Lizardking
Copper - Posts: 184
Posted: May 09, 2005 at 3:28 PM / IP Logged
I figure the two connectors that broke, all they where is crimped.. So I should have no problems....
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
