lcd power
plyrh8r1
Member - Posts: 31
Posted: March 18, 2006 at 11:04 AM / IP Logged
i was wondering if i can run my 2 lcd screens power cord to my fuse block for my amps
xscash
Copper - Posts: 317
Posted: March 18, 2006 at 11:58 AM / IP Logged
sure just use the correct fuse for the lcd's
XS
plyrh8r1
Member - Posts: 31
Posted: March 18, 2006 at 12:03 PM / IP Logged
do i need to use a relay
12tech
Member - Posts: 8
Posted: March 18, 2006 at 12:42 PM / IP Logged
depends on how u want them to operate. i would suggest using a fuse and a toggle switch.
kam
xscash
Copper - Posts: 317
Posted: March 18, 2006 at 3:20 PM / IP Logged
are you trying to connect the power or the ign? if power then just connect.....you will need a relay if you are trying to control them from the remote wire.
XS
plyrh8r1
Member - Posts: 31
Posted: March 19, 2006 at 10:22 AM / IP Logged
just power i will use a toggle swicth thanks for da help
