How to disconnect a special feature
JazzyJ
Posted: January 08, 2003 at 3:56 PM / IP Logged
The guys who put in my Accelvision Monitor put in a safety feature, that you must have the emergency break on in order for the monitor to come on.  This is very displeasing, in that i want my passengers to have a great ride.  If any one out there has had this same problem could they please offer some help.  I just want to be able to drive with the monitor on, which of course this feature does not allow.  Any help would be appreciated. Thanks.
Jazzy J
auex
Platinum - Posts: 5,041
Posted: January 08, 2003 at 5:00 PM / IP Logged
That is there for a reason.... But if you really need to bypass that then find the wire that is tagged to the e-brake switch and ground it.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Mrreaer6
Posted: January 10, 2003 at 8:20 PM / IP Logged
I've installed many screens in dashes where the speedometers are and have bypassed the safety features numerous times. Take the brake wire usualy black or blue and ground it. This will fix your problem and give your passengers a quality ride with movie.
Mr Reaper owner/installer
navion20is
Member - Posts: 37
Posted: January 22, 2003 at 8:43 PM / IP Logged
by grounding it you mean hook it up to metal
navion20is
Member - Posts: 37
Posted: January 22, 2003 at 9:26 PM / IP Logged
can i hook it up to the stereo ground
gmc4x4
Copper - Posts: 62
Posted: January 22, 2003 at 11:28 PM / IP Logged
you can ground it anywhere, or you can put it on a switch so that you can turn it off or on with the switch
Sunday, October 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
