F150 - Mounting source box on sony xav-7w
02HarleyF150
Posted: January 16, 2003 at 2:31 AM / IP Logged
Just wondering where other people have mounted their source unit box thingies ( i hope you know what im talking about - its the box that is seperate from the head unit which u plug all of the inputs into). I have a 2002 F150, and  i was thinkin about either under the dash on the passenger side, in the center console, or under the passenger seat. Any input would be appreciated! Thanks in advance!!
2002 Black Harley Davidson F150
Robdude30
Member - Posts: 29
Posted: January 16, 2003 at 6:26 AM / IP Logged
Depends on how big the thingy is. I have a Panasonic HU that has a small external power supply/speaker connection box and I mounted it under the dash to the right of the steering column (behind the trim piece that runs under the steering column). If you have one of the larger units, either mount it under the seat or possibly behind the glove box (there is some space in there).
Good Luck! F150 - Mounting source box on sony xav-7w -- posted image.
Platinum - Posts: 12,488
Posted: January 16, 2003 at 6:48 AM / IP Logged
I have mounted my CPU for my AlpineCVA unit under the passenger side seat and built a bracket & cover to protect it from damages and from sight. As long as it has ventilation in the area that you are installing it in, you should be fine ( unless it does not have an amp built into it, then it doesn't matter where it is installed  as long as it fits )
F4Pilot
Copper - Posts: 113
Posted: January 16, 2003 at 12:17 PM / IP Logged
Honda Odyssey
Velcroed to air duct, behind the dash, passenger side, above glove box.  Was able to use 1.5ft rca's.  Hope this gives you ideas.
02HarleyF150
Posted: January 17, 2003 at 2:15 AM / IP Logged
Okay guys, thanks a TON on the 411!! Appreciate it! Ive decided to mount it in this litte side pocket thingy on the center console on the passenger side. Man this site is awesome, and it is the posters that make it this way!!
auex
Platinum - Posts: 5,041
Posted: January 18, 2003 at 8:42 PM / IP Logged
If there is enough room you may be able to mount the box on the passengers front top of the dash.  The panel will pull right out and it is right behind the radio.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
