'12 Maxima remote start problem
armbruster
Member - Posts: 32
Posted: November 14, 2015 at 7:24 PM / IP Logged Link to Post Post Reply Quote armbruster
I have a Maxima that I installed a Python 4104P with Smart Start using a DBALL2 in D2D and the system keeps dropping the remotes and stops working. I can reprogram the remotes and it will work for a week or so and then drops the remotes again.
I have replaced the RS and DBALL twice with the same result...tried W2W even with no luck. Looking for any suggestions
shark mobile
Copper - Posts: 83
Posted: November 15, 2015 at 9:45 PM / IP Logged Link to Post Post Reply Quote shark mobile
I know it sounds silly but find a new ground...bad ground will cause all sorts of oddities...and since you replaced the units it has to be a wiring issue...drivers kick is usually a decent place...cheers
Solder, tape, repeat!
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
