2002 Ram Remote Start
Moderator - Posts: 12,488
Posted: April 21, 2003 at 8:38 AM / IP Logged
What wire did you attach to the parking light output of the RS ?
wvumounty
Member - Posts: 11
Posted: April 21, 2003 at 2:30 PM / IP Logged
black / yellow
Posted: April 21, 2003 at 2:47 PM / IP Logged
Wow, that's weird ?? If you add 12 volts to the parking light wire of the RS, does the parking lights turn on ? Try this and post your results.
wvumounty
Member - Posts: 11
Posted: April 21, 2003 at 3:57 PM / IP Logged
oh... also the lights run when the truck is started... do you still want me to test the power to the wire?
Posted: April 21, 2003 at 5:39 PM / IP Logged
Yes, test the wire with the truck off. It should not matter if the truck is on or not if you are to add 12 volts to this wire, the parking lights will still turn on.
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
