Tacoma 2010 and Viper 4706v
Posted: April 12, 2015 at 9:36 AM / IP Logged Link to Post Post Reply Quote howie ll
Hood pin wire will read 12V+ pin wont read anything.
Posted: April 12, 2015 at 9:38 AM / IP Logged Link to Post Post Reply Quote howie ll
Did you test as I suggested before black probe to wire, red to 12V+? If so pull the H2 plug and see if that's still the case.
tedmond
Gold - Posts: 4,610
Posted: April 12, 2015 at 9:56 AM / IP Logged Link to Post Post Reply Quote tedmond
i would just depin the hood pin from the connector for testing purposes.
Howard:
Well you train yourself to become familiar with the environment. Give it 5 months and the fear diminishes. It's really all mental training. If you are enjoy medical drama shows, perhaps House M.D. Will entertain you.
Ted
Compustar Expert
Posted: April 12, 2015 at 10:05 AM / IP Logged Link to Post Post Reply Quote howie ll
Don't like house, prefer G. Anatomy.
There's a real throw up program on Sky over here, it will probably get to HBO soon called Critical set in a major trauma ops room, very stomach churning though.
tedmond
Gold - Posts: 4,610
Posted: April 12, 2015 at 10:10 AM / IP Logged Link to Post Post Reply Quote tedmond
I mean your Tacoma is probably one of the easier cars to do out there. high current ignition, ground, tach, locks, horn, hood pin, bypass and you're done.
Not much else to it. as mentioned your hood pin wire should only show ground when the hood is open.
Red probe to constant 12, black to hood pin wire. When the hood is open it'll show ground on your meter
Ted
Compustar Expert
cherxiong
Copper - Posts: 164
Posted: April 12, 2015 at 10:12 AM / IP Logged Link to Post Post Reply Quote cherxiong
Will test again after lunch : ) my hairs are falling : )
cherxiong
Copper - Posts: 164
Posted: April 12, 2015 at 12:07 PM / IP Logged Link to Post Post Reply Quote cherxiong
Yea..should be easy. I got everything connect quick, if not that fail to start should be done in 3 hours already
tedmond
Gold - Posts: 4,610
Posted: April 12, 2015 at 6:39 PM / IP Logged Link to Post Post Reply Quote tedmond
I'm going with your brain is toast and you need a new one. I have never experienced a brain throwing MULTIPLE shut down errors - even when disconnected.
Ted
Compustar Expert
cherxiong
Copper - Posts: 164
Posted: April 12, 2015 at 7:09 PM / IP Logged Link to Post Post Reply Quote cherxiong
Yea. I think something's wrong with the R/S, too. I will just keep it with the second starting. Hope it last for at least a year or two.
Thanks for all the helps and trouble shooting. I am giving up. : )
The way, it's running is like the timer mode problem.
Posted: April 13, 2015 at 1:43 AM / IP Logged Link to Post Post Reply Quote howie ll
Never EVER had a DEI 4/5X brain failure. It's always an installation error.
Usually brain is fried because of an installation mistake.
Page of 11
Monday, May 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
