draw for me a diagram
machpilot
Member - Posts: 15
Posted: February 16, 2016 at 4:46 PM / IP Logged Link to Post Post Reply Quote machpilot
Please draw for me a Latched On/Off Output Using a Single Momentary Positive Pulse - Negative Output
This but in reverse: https://www.the12volt.com/relays/relaydiagram23.html
the12volt
Administrator - Posts: 3,955
Posted: February 16, 2016 at 4:52 PM / IP Logged Link to Post Post Reply Quote the12volt
Explain what you're asking when you say "in reverse".
draw for me a diagram -- posted image. the12volt • Support the12volt.com
machpilot
Member - Posts: 15
Posted: February 16, 2016 at 7:01 PM / IP Logged Link to Post Post Reply Quote machpilot
Sorry, I thought I did. The example in the link posted on this site is a Latched On/Off Output Using a Single Momentary ((Negative Pulse - Positive Output)).
I asked please for a Latched On/Off Output Using a Single Momentary ((Positive Pulse - Negative Output)).
The Pulses, and outputs are what I would call reversed.
the12volt
Posted: February 16, 2016 at 7:35 PM / IP Logged Link to Post Post Reply Quote the12volt
Yep, you're sure did.
I'll test the configuration on the bench tomorrow if I have time, then draw it and post it if it works. In theory you would flip the diodes and reverse the polarity of the inputs to the switch and relays to achieve what you want (positive input, negative output).
machpilot
Member - Posts: 15
Posted: February 16, 2016 at 8:40 PM / IP Logged Link to Post Post Reply Quote machpilot
Thank you. It could also be a negative pulse - negative output. The single momentary on/off, and negative output is the important part.
the12volt
Posted: February 16, 2016 at 8:49 PM / IP Logged Link to Post Post Reply Quote the12volt
You're welcome. You could use that diagram and simply add a relay to the 12V+ output to also get a negative output.
Additional relay connected as follows:
12V+ output from that diagram to 85
ground to 30 and 86
87 will be a negative output
machpilot
Member - Posts: 15
Posted: February 16, 2016 at 9:00 PM / IP Logged Link to Post Post Reply Quote machpilot
Yes, that is what I did using the available diagrams here on the site, but it adds another relay.
Here is a drawing of the complete system. It ends up with 11 relays. I had hopes that someone could get it down to 8 maybe.   [URL=http://s790.photobucket.com/user/dashenchman/media/11%20Relay%202%20Switch_zpspy83sdli.jpg.html][/URL][IMG]https://i790.photobucket.com/albums/yy190/dashenchman/11%20Relay%202%20Switch_zpspy83sdli.jpg[/IMG]
machpilot
Member - Posts: 15
Posted: February 16, 2016 at 9:03 PM / IP Logged Link to Post Post Reply Quote machpilot
the12volt
Posted: February 17, 2016 at 3:54 PM / IP Logged Link to Post Post Reply Quote the12volt
machpilot
Member - Posts: 15
Posted: February 17, 2016 at 4:36 PM / IP Logged Link to Post Post Reply Quote machpilot
Much praise, and thank you to "the12volt".
I will get this soldered up, and tested this weekend. It should fit my needs perfect.
