2000 yukon, remote start
mo12v
Posted: November 26, 2005 at 8:43 PM / IP Logged
You probably are aware of this:
http://www.wiringinstructions.com/238.htm
You could be facing both issues of ByPass & Tach...........
I would want the ByPass hooked up & programmed, AFTER the TACH is learned
MO
tintman97
Copper - Posts: 113
Posted: November 26, 2005 at 9:02 PM / IP Logged
dumb question how do u learn tach without the truck running? i thought it had to  run to get it tuned in.
Snapper
mo12v
Posted: November 26, 2005 at 9:13 PM / IP Logged
YAH./.............. Start the Truck with Key...........Program TACH or SMART...then Program ByPass after you turn key off
MO
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
