2006 altma, aps 997 problem
Ohmz
Copper - Posts: 193
Posted: November 26, 2007 at 6:27 PM / IP Logged
I installed a APS 997 pager/remote start on a 2006 altima. The alarm/pager and remote start worked fine. A few days later the main 80amp ECN fuse blew. This happened while the car was parked. Customer did not even try to remote start or nothing. The part that puzzled me was that door lock still worked with the pager. This happened a few times with the vehicle (almost every other week). I removed the system for a few months just to see if it would happen again - and of course with my luck it didn't happen again. Has anyone heard or experience this problem before? Any suggestions would help. Thank you in advance.
Ohmz
Copper - Posts: 193
Posted: November 29, 2007 at 10:32 AM / IP Logged
Yeah I know this one was a real odd-ball one. Thanks for reading...
KarTuneMan
Platinum - Posts: 7,056
Posted: November 29, 2007 at 4:57 PM / IP Logged
80amps......man!  When you removed the unit......anything look suspect?
For that GIANT fuse to "pop" on it's own, there must have been a slight tell tale sign of something wrong!
Have you seen the car again yet?
tedmond
Gold - Posts: 4,610
Posted: November 29, 2007 at 5:48 PM / IP Logged
like kartuneman said...WHOA, 80 amps is alot, an alarm is only 20 amps or sumthing max. there could have been a short while u were stripping wires. as u mentioned before, if its the main fuse, how did it pop and ur keyless is still working? does the car have dual fuses? im sure there is one at the battery, and one inside the fuse box in engine bay. check to see what is the recomended fuse. the customer might have changed the fuse if it did pop before to somthing lower.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
