dB estimate
walty220
Copper - Posts: 75
Posted: February 02, 2004 at 9:00 PM / IP Logged
ive gotta 12" HE2 Fosgate with a 401s Fosgate amp. Its in a sealed box, pushin 400 watts RMS, any body have any clue what kind of spl that might have, even though its punch series?? just guess at my dB, thanks
jpranwez
Member - Posts: 33
Posted: February 02, 2004 at 9:41 PM / IP Logged
Have it measured. Somebody more experience than I might be able to tell you, but they'll want to know what kind of car and probably some other stuff.
walty220
Copper - Posts: 75
Posted: February 02, 2004 at 9:57 PM / IP Logged
1983 cutlass supreme,its in my trunk
Teamrf
Gold - Posts: 1,031
Posted: February 02, 2004 at 10:23 PM / IP Logged
Well it's hard to estimate db's...you have to take in consideration about your voltage...box size...ports or no....trunk size...insulation...it's a lot of things you have to think about before you can estimate dbs it's almost impossible to guess it. Because to go from 100 dbs to 103 dbs you have to double something to get there. So without having it metered you are basically clueless.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Julian59
Member - Posts: 24
Posted: February 03, 2004 at 1:13 AM / IP Logged
Below 98db for sure. the speakers are not efficient enough.
Julian59
Be Smart Never Assume
Improvise Adapt and Over Come
Installer/Technician 20 years
forbidden
Platinum - Posts: 5,353
Posted: February 03, 2004 at 1:04 PM / IP Logged
I would bet that he is above 115 db, maybe even closer to 125db. Most single sub systems are certainly capable of this, but like stated above, have it metered. There are a lot of factors that add to spl levels, teamrf mentioned some above, another is cabin gain, and it will have a lot to do with your reading.
Julian59
Member - Posts: 24
Posted: February 03, 2004 at 1:56 PM / IP Logged
walty220
      Ok here are the specs,  no guessing  just the facts! The Rockford Fosgate HE2 (RFD3212) it's efficientcy is only 87db@ 1watt / 1meter  Power Handling (RMS) is 400  Max is at 800 at 4 ohms. If you max this out at 800 watts you'll only maybe get an increase of 4 db. The numbers don't lie, always do the math before you buy.  Sorry if this isn't what you want to hear.
Julian59
forbidden
Posted: February 03, 2004 at 2:20 PM / IP Logged
Julian, not to knock you at all but do a little more research into the math involved. If It generally assumed that a doubling of power is a gain of 3db, then we need to check the math. If it is in a ported enclosure, then add 3db as well, add cabin gain, this is pressurizing a small airspace, not a big room. A factory stereo with no sub can play above 100db. I stand firm that the system should play above 115db and probably close to 125db. Please let me know what you think on this if you have or I have any misconceptions.
1 watt = 87db
2watt = 90db
4watt = 93db
8watt = 96db
16watt = 99db
32watt = 102db
64watt = 105db
128watt = 108db
256watt = 111db
512watt = 114db
Julian59
Member - Posts: 24
Posted: February 03, 2004 at 3:29 PM / IP Logged
Forbidden
       Thank you for the heads up, but I'm sorry to say that's not right. The speaker in question is rated at 87db @ 1 watt / 1 meter. There is no way this speaker will ever come close to those figures you have. It doesn't matter what type of enclosure this is in. Rule of thumb is in order to gain 3db is to increase the power no lell then 100 watts. You will gain SPL but no more then 3 dbs +- .05.  I hav't read the MECP manual in about 10 years. but I do know that's this is in there. Check it out.  The key word here is DBs.
Thx
Julian59
jpranwez
Member - Posts: 33
Posted: February 03, 2004 at 4:34 PM / IP Logged
Exactly what does the efficiency rating mean. I was told it's the sound level that a sub is most efficient but that sounded odd.
Page of 3
