07 silverado, alarm, remote start
splaudio
Copper - Posts: 237
Posted: December 30, 2007 at 6:49 PM / IP Logged
using a ultra start and alarm 2270 with a can-sl2i bypass.  along with wire magic's starterenabler (2 relays and a 1290 resistor between the pink/black wire).
i can remote start but the truck says service veichle security then i put the key in and it goes away as soon as i touch the key sence with the key. then i can drive it and try to remote start and the starter flashes telling me there isnt a tach signal. i restart with a key then it will remote start. please help...
Platinum - Posts: 12,488
Posted: December 30, 2007 at 6:54 PM / IP Logged
For the new GM's use tachless and set starter for 3 seconds.
splaudio
Copper - Posts: 237
Posted: December 30, 2007 at 6:58 PM / IP Logged
you really think its the tach? i was using the tach output from the can-sl2i for my tach signal...
splaudio
Copper - Posts: 237
Posted: December 30, 2007 at 6:59 PM / IP Logged
and sorry the relays are between the pink black the starter with resistor is going to the white wire...
Posted: December 30, 2007 at 7:15 PM / IP Logged
From different installers I've heard that the tach signal is not that great on the CANSL-2 modules. Use tachless first as this is a quick test to see if it's the tach or the starter bypass.
splaudio
Copper - Posts: 237
Posted: December 30, 2007 at 7:50 PM / IP Logged
well i just went out and undid the tach wire so it will voltage sence.
i was testing and i can remote start it a bunch of times as long as the dome light stays on before it dimms out. if i start with a key let it sit for 2 mins it wont remote start,why?
the lights kick on so dose the fuel pump but the security light dosent come on like that shut it off.
splaudio
Copper - Posts: 237
Posted: December 31, 2007 at 8:55 AM / IP Logged
well i dont know if the can-sl2i will work for my silverado newbody. it will remote start every time with the key next to the key cylinder.  or will remote start within 2 mins of starting with a key. i dont have a cansl2 onhand and it is 5 days to get to me...
Posted: December 31, 2007 at 12:42 PM / IP Logged
2007 Chevrolet Silverado New Body Note(s): Firmware 12.0 or newer
Do you have this version or not ?
Also, it states in the instructions that everytime the CANSL-2 is disconnected, the vehicle has to be restarted with the key.
splaudio
Copper - Posts: 237
Posted: December 31, 2007 at 3:24 PM / IP Logged
nope my distributor sent me the SL2i and i figured out earlier today it was the WRONG bypass. the sl2i dosent have the transponder bypass and that is the part i need.
my distributor asks for make of veichle then sends what i need, i told him a 07 silverado newbody.  the sl2i sheet says 07 silverado but probly the classic which dosnt need the transponder.
wized me off i had to unhook the double relay and resistor for start and the connections at the green bcm plug because the new one states connect ONLY at the keybarrel connector.
i almost totally stopped doing starters this yr and kept my focus on high end audio(parttime shop i have). i only do starters and alarms for family,close friends as of now.  it is hard to keep up on all the new veichles these days. i wanted to keep my winter alittle more open for snowmoible season because last yr i got stuck working while family and friends were out having fun. thank you for ur help and wish you and ur family a fun and safe new yr...
Posted: December 31, 2007 at 4:16 PM / IP Logged
LOL, I hate it when that happens. Think that the supplier gets you the right stuff and then find out afterwards that it's not 07 silverado, alarm, remote start - Last Post -- posted image. Have a happy new year and don't drink and sled.
