window goes down when door opens
Posted: May 02, 2008 at 5:08 PM / IP Logged
That's because the switch goes to ground to complete the interior light circuit, if you don't understand this you should take your Subie to a dealer and get them to do it for you.
stevensti
Member - Posts: 16
Posted: May 02, 2008 at 6:12 PM / IP Logged
why put the positive then? remember its positive when pushed in and negative when out.
jmsounds
Copper - Posts: 99
Posted: May 03, 2008 at 10:22 AM / IP Logged
i think i figure out for you     use a relay    (86) 12v    85 to door pin switch   (30) to ground and (87a)  to 530 up       this is to go up when the door is down   to make the window go down conect the door pin switch to the       530      hope this will help
stevensti
Member - Posts: 16
Posted: May 03, 2008 at 10:44 AM / IP Logged
Youre the Man I think this my work. But alittle confused about connecting tehe relay to the 530 with the pin switch. could you post a diagram with just the relay connected to the 530. you said to make the window go down connect the pin switch to the 530 but what wire on the 530 to connect to?
Thanks for your help man! it sounds like it will work once i figure out what wire for that last one. Thanks again
chriswallace187
Gold - Posts: 1,661
Posted: May 03, 2008 at 1:20 PM / IP Logged
The reason your door switch shows 12 volts when pushed in is because your meter's red probe is seeing the voltage at the other end of the wire, which is coming from the BCM or from the interior lights circuit.
Any normal (-) door trigger vehicle will read the same - you can use the door pin wires directly to trigger the 530 if you so desire.
C Renner's Auto Electronix
stevensti
Member - Posts: 16
Posted: May 03, 2008 at 3:08 PM / IP Logged
Well Heres That diahram Using the door Pin as the activator Switch. This is with out using the Relay as mentioned by jmsounds. i will drwa up another diagram and post it. thnaks all please note that the yellow wire is actually the white (2/2 to down switch 1) and all wires are as is on the 530 and the grey (2/5) is not being used in this diagram. Is it correct?????????????window goes down when door opens - Page 2 - Last Post -- posted image.
stevensti
Member - Posts: 16
Posted: May 03, 2008 at 5:53 PM / IP Logged
Here is that diagram using the relay that was recomended I think this may work better and i dont have to F with the door pin too much. I hope you guys looked at it and approve .  I will wire this into the car as soon as i get the dei530T delivered to me. and let you all know how it works. Thanks Guys you,re all pros and you all were VERY Helpfull with this issue. im am not closeing this post yet thought. not until i post my results! maybe a video as well. As usual if you have any input towards this please post it.  THANK YOU ALL!window goes down when door opens - Page 2 - Last Post -- posted image.
