2008 scion xd factory keyfob disarm alarm
hurleyloser
Copper - Posts: 157
Posted: May 11, 2008 at 9:04 PM / IP Logged
Chris has a good point, I forgot to mention that. The only way to allow the factory fobs to continue working with the car on is to cut the ignition input to the factory keyless module, and this is on a case to case basis when this solution is available.
hope this helps.
MECP Master Certified Technician
ASE A6 Certified Technician
tedmond
Gold - Posts: 4,610
Posted: May 12, 2008 at 6:06 AM / IP Logged
oh man, i have been misleading this whole time. i thought he wanted to retain factory because i thought it was wailing when he unlocked the doors. Im sorry for the info i have been feedin you.
tmrepp
Member - Posts: 19
Posted: May 12, 2008 at 3:13 PM / IP Logged
It's all good. Seems like a lot of work with small wires on a small circuit board (circuit board being the autopage keyfob) that wouldn't hold up very well. Maybe eventually I will end up doing this, but for the time being, it's not worth it to me. Thank you for all of your time, I appreciate it! I really wish they put a line in disarm on the alarm. Would make it a lot cheaper and easier. Yaknow?
tmrepp
Member - Posts: 19
Posted: May 12, 2008 at 3:21 PM / IP Logged
You guys have any idea why the Autopage would (occasionally) only disarm and not unlock the locks no matter how many times I lock/unlock it, I have to use my key (or OEM keyless entry).. Any ideas? I'd like to put keyhole covers on.
hurleyloser
Copper - Posts: 157
Posted: May 12, 2008 at 8:37 PM / IP Logged
It might need to be programmed for a double pulse unlock. Some BCM connections on Nissans will unlock with one pulse, but after the BCM goes to sleep it will require two, this could be the same with yours. Then again, I don't know if you have double pulse programmed already.
tmrepp
Member - Posts: 19
Posted: May 13, 2008 at 10:11 PM / IP Logged
I could set that up. It's not necessarily when it's sitting for a while. It did it yesterday, nothing out of the normal of what I usually do. Stop car, put in neutral put the e-brake on, turn car off. turn headlights off if they're on, get out of the car..and then lock it with the remote. Went inside to grab my paycheck, came back out and no matter how many times I hit the unlock button, or lock then unlock, etc. it wouldn't work.
