06 dodge 3500, remote start
paul h
Copper - Posts: 109
Posted: January 20, 2009 at 10:55 PM / IP Logged
OK..working with a Dodge 3500 truck, diesel.  Wiring diagram is showing a (-) PURPLE / brown that is a second starter wire and is negative trigger thru an 180 ohm resistor and say must use a relay.  No problem on the relay part....BUT this is what confised me!  Wiring also shows the Accessory is the same as the second starter wire above and shows it is a negative trigger thru a 610 ohm resistor and also must use a relay.
My question is this....can I make 1 tap off this PURPLE / brown wire, run my resistors off that tap and then to the relays??  Essentially...its the same as making 2 separate taps, correct??
Fill me in if I'm wrong!!  And thanks in advance for the help!
ckeeler
Gold - Posts: 1,461
Posted: January 21, 2009 at 10:15 AM / IP Logged
Thats correct.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
