doorlock problems on viper 560xv
downsouthplaya
Member - Posts: 38
Posted: August 14, 2009 at 6:45 PM / IP Logged
the switch has a lock, unlock and ground...
I know I may have been the cause of the alarm failing. Its been around 8 years or so since I last touched a car. I use to install for the roadshop in circuit city back in its prime. Relays and door locks were not my expertise. I have learned from my mistake and it may be another 8 years or so since I touch another car! (lol)
t&t tech
Platinum - Posts: 2,622
Posted: August 14, 2009 at 7:17 PM / IP Logged
well just ground the negative wire and the other two go to their respective places on the relays with diodes on them, so you initial mistake doesn't recur! Cheers!
downsouthplaya
Member - Posts: 38
Posted: August 21, 2009 at 1:25 PM / IP Logged
I have everything I need (diodes are not easy to find around here) and just about ready to install everything. I dont want any mishaps...
The factory GM switches have a lock, ground and unlock prong I have to wire into. The ground goes to ground and I know the door lock wires are dioded with the striped towards the alarm. After looking over my relays I believe i'm wiring the lock and unlock wires into the alarm outputs on the relay...just wanted to get expert opinions if my wiring would be correct.
t&t tech
Posted: August 21, 2009 at 4:08 PM / IP Logged
That's correct!
downsouthplaya
Member - Posts: 38
Posted: November 02, 2009 at 9:28 AM / IP Logged
I know its been a while but I still can't get these added door locks to work! Any help would be appreciated!
t&t tech
Posted: November 03, 2009 at 3:32 PM / IP Logged
What's happening now?
downsouthplaya
Member - Posts: 38
Posted: November 03, 2009 at 3:41 PM / IP Logged
The doorlocks work with the alarm great, just cant get them to work with the switches like an original power doorlock truck.
I grounded the ground and sent the lock and unlock to the outputs on the relay like instructed, but they still dont work. I been busy at work and havent had a chance to fiddle with the truck much or come on here to ask. Any help would be much appreciated.
t&t tech
Posted: November 03, 2009 at 3:59 PM / IP Logged
Have you verified with a meter that the terminals are applying ground when the switch is depressed? Have you dioded both inputs to the relays?
Page of 3
