06 mazda 6, build relay for door locks
spingjp
Member - Posts: 7
Posted: September 22, 2009 at 7:20 PM / IP Logged
ok but im confused on how to hock up two relays to the lock system... do i just basically make a realay for lock wire and one relay for unlock wire.. but from my understanding my car is one wire unlock and lock...
t&t tech
Platinum - Posts: 2,622
Posted: September 22, 2009 at 9:28 PM / IP Logged
That's correct mr spingjp! one wire is lock and unlock! The relay is a must when your application requires resistors! Reason being is that there would already be resistance on the alarm's output circuit placing the resistor inline with this directly would therefore increase the resistance and result in a no function result! The relays ensure that there is very minimal resistance if any to prevent this from occuring!
That being said! Here's how the relays would be wired!
The lock relay
Pin 85- lock trigger
Pin 30- ground
Pin 86- twelve volts constant
pin 87 to the car's lock wire via the resistor
The unlock relay
Pin 85 - unlock trigger
Pin 30- ground
pin 87 -to unlock wire
t&t tech
Posted: September 22, 2009 at 9:31 PM / IP Logged
Also Howard! I thnik you made a mistake with your description of the relays! your setup would result in a positive output on pin 87 of the relays !06 mazda 6, build relay for door locks - Page 2 - Last Post -- posted image.
Posted: September 23, 2009 at 1:24 AM / IP Logged
Also Darren you're absolutely right and I thank you and apologise to spingjp. How to blow fuses, or in fact watch nothing happen.
