03 f 250 heated seats rs
localed
Member - Posts: 9
Posted: October 23, 2009 at 7:02 PM / IP Logged
what type of signal and where to do i need to activate heated seats during remote start? 03 f250 xlt lariat supercab .
tommy...
Gold - Posts: 1,901
Posted: October 23, 2009 at 8:06 PM / IP Logged
Do you have a switch to turn them on...? I would start there...! Do you have a meter...? If the answer is NO to the second question...Buy one or take it to a shop...!
M.E.C.P & First-Class
chev104275
Gold - Posts: 1,436
Posted: October 24, 2009 at 8:01 AM / IP Logged
is there just an on and off switch for the heated seat ?   it looks like there is a dark GREEN/ violet that gets grounded through the switch to turn them on
localed
Member - Posts: 9
Posted: October 24, 2009 at 6:48 PM / IP Logged
joe , there is a button on the side of the seat that you push and a led lights up beside it , the seat turns on and turns itself off after about 10 minutes and the led goes out. it will not turn back on unless you push the button again so it think there is a timer in the circuit, so do you think i could run a neg pulse from my trunk pop to the dkgn/vi wire ?
thanks alot , ed
chriswallace187
Gold - Posts: 1,661
Posted: October 24, 2009 at 7:21 PM / IP Logged
If you have either an auxiliary channel or a dedicated defroster output from your remote start available, and it can be programmed to send a momentary pulse, you can just connect that wire directly to the momentary wire from the switch(assuming it pulses (-), of course).
C Renner's Auto Electronix
localed
Member - Posts: 9
Posted: October 25, 2009 at 3:14 PM / IP Logged
my trunk pop output was (-) pulse , i ran a from it to the gn/vi wire at the switch , the heated seats work perfect. thanks alot joe and chris you were a great help.
   ed
