08 equinox transponder program issue
brhaugen
Copper - Posts: 275
Posted: November 24, 2009 at 7:51 PM / IP Logged
I am trying to program a RFLCHGM to to a 08 Equinox.
First, when I jump the IGN, the dash lights do not activate. So I jump both the IGN and the ACC. I still only get a "Service Theft Deterrent System" message when I go to program the key.
Anyone have any tricks here? Do I have a bad RFLCHGM or am I doing something wrong.
I have followed the procedure in the RFLCHGM manual and form the Vehicle Owners manual.
Brent Haugen
Fargo, ND
Chris Luongo
Platinum - Posts: 3,746
Posted: November 25, 2009 at 6:16 PM / IP Logged
I've always used a regular key-in-a-box module with an aftermarket key, just because it's less expensive, so I'm not familiar with that module.
But, will the car remote start and run successfully if you leave an existing key in the ignition?
Also, instead of using a jumper wire to turn on the ignition, you can just activate your remote starter.
At whatever moment the module's programming instructions tell you to remove your jumper wire, simply press the brake, disabling the remote starter.
robertsc
Copper - Posts: 337
Posted: November 25, 2009 at 6:36 PM / IP Logged
Usually to program bypasses like that I turn the key on until the symbol disappears they I turn the key off then remote start works best for me.
brhaugen
Copper - Posts: 275
Posted: November 25, 2009 at 7:54 PM / IP Logged
I will try setting the rs to 30 second wait to start and try that.
Thanks for the help.
Brent Haugen
Fargo, ND
Mike M2
Platinum - Posts: 2,652
Posted: November 25, 2009 at 9:34 PM / IP Logged
If you can't get it to work, Idata makes module for this that's works very well. Easy programming too...
Mike M2
Tech Manager
CS Dealer Services
yimke
Copper - Posts: 417
Posted: November 26, 2009 at 10:35 AM / IP Logged
Just take the key apart and remove the transponder chip. Then turn the cylinder. Much easier.
jim hunter
Silver - Posts: 351
Posted: November 26, 2009 at 11:07 AM / IP Logged
key on a 2008 doesnt come apart! only on the 2010 does it come apart and you have to be very careful not to break it or lose parts, i like chris just buy a blank circle plus key and program that and place it in a coffin box, works flawlessly and is much easier, this vehicle in general is very easy to do with this method
