compustar cm5000 for push start?
equate
Copper - Posts: 118
Posted: November 28, 2009 at 12:09 PM / IP Logged
I see there is a wire "trigger start" at PIN12 of CN3. Can it be hooked as push start? If yes, is it that give it a negative pulse, then it starts? Does it need key for driving?
Platinum - Posts: 12,488
Posted: November 28, 2009 at 12:46 PM / IP Logged
The trigger start is a (-) pulse and does require the key for driving, but you still have the mechanical lock on the steering column that you have to bypass. Also, the trigger start doesn't work if you have the temperature start option ON.
equate
Copper - Posts: 118
Posted: November 29, 2009 at 10:50 AM / IP Logged
Thanks for your help.
How to bypass it? is it key sense wire?
equate
Copper - Posts: 118
Posted: November 29, 2009 at 10:52 AM / IP Logged
by the way, you mean it doesnt need key for driving. then when I press foot brake, it wouldnt stop, is it correct?
Posted: November 29, 2009 at 11:11 AM / IP Logged
You still need the key for driving because there's a mechanical lock on the steering column. The key sense does not unlock the mechanical steering lock. You will need to remove the lock pin from the cylinder
KPierson
Platinum - Posts: 3,527
Posted: November 29, 2009 at 2:49 PM / IP Logged
I'm pretty sure you'll still need the key to prevent the remote start from shutting off when you hit the brake, the timer times out, you over RPM it, or pop the hood.  (-) inputs are not meant for push button start solutions!
Kevin Pierson
equate
Copper - Posts: 118
Posted: November 30, 2009 at 8:20 AM / IP Logged
So what about push start kit sets? Do they unlock the steeling?
Or I still have to remove the lock PIN?
KPierson
Posted: November 30, 2009 at 8:56 AM / IP Logged
No, the steering wheel lock is mechanical - there is no way to electronically unlock it - you must make mechanical modifications that, in most cases, will be fairly permanent and will completely bypass the that aspect of security.
On cars that come with pushbutton start from the factory they use a secured electronic solenoid to electronically unlock the steering column.  You may be able to find a steering column from a newer model car and retrofit it - but I'm guessing that would be a bit expensive due to the custom work that would be needed.
Kevin Pierson
