2001 alero passlock ii
bgraper
Member - Posts: 27
Posted: December 10, 2009 at 6:18 AM / IP Logged
I am getting ready to install a remote start into the girlfriend's car. I have a T-harness and all of my ignition wiring harness connections ready to go, the lock/unlock I have wired in (using relays and resistors)...trunk....door sense...horn...parking lights...etc
I know I need a Passlock II bypass module but am having some trouble finding good information for this one.
What module should I be looking at getting? What wires need to be spliced into for the Alero?
Platinum - Posts: 12,488
Posted: December 10, 2009 at 7:57 AM / IP Logged
I suggest using the iDatalink ADS-TBSL-PL for this vehicle. Very simple installation and inexpensive.
zerepdivad
Silver - Posts: 605
Posted: December 10, 2009 at 1:22 PM / IP Logged
use the 2 relay method.
A DMM is a beautiful thing.
bgraper
Member - Posts: 27
Posted: December 14, 2009 at 11:18 AM / IP Logged
I am a little confused.
This is the wiring diagram I found for this vehicle's installation type.
The "Pink - Ignition Input" - is incoming to this unit? Or is an input for the ignition wire?
I guess it really doesn't matter, it needs to be placed in-line with the ignition wire. Correct? How does it disarm the Passkey II? Is it through the data port or through the ignition wire input?
2001 alero passlock ii - Last Post -- posted image.
Thack79
Silver - Posts: 526
Posted: December 14, 2009 at 11:42 AM / IP Logged
its data.  not sure which alarm you have but the ignition input on the moduel connects to the igintion of the car.
bgraper
Member - Posts: 27
Posted: December 14, 2009 at 11:44 AM / IP Logged
Okay that makes sense. I was just confused because other modules show 3...4...5 connectiosn to the steering column wiring harness and this only shows 2.
