factory locks disarm aftermarket alarm
dasbogie
Silver - Posts: 514
Posted: October 14, 2010 at 2:33 AM / IP Logged
yes indeed
Advanced
Posted: October 14, 2010 at 2:35 AM / IP Logged
Yes but the original Euro equivalents from about 10 years ago tied into the direction indicators as well as lock sensing, both had to activate to disarm the add-on alarm. Because in Europe, operating the factory remote brought on the indicators (lights) as well.
91stt
Silver - Posts: 564
Posted: October 14, 2010 at 9:14 AM / IP Logged
a471789 wrote:
I hate to ruin your great idea, but if you have an alarm that has a disarm input and tie it to factory unlock and someone breaks into the vehicle...doesn't that mean if they press the unlock button on the inside, it will disarm the alarm as well? Just a thought.
Not necessarily, it depends on the vehicle. Some vehicles have dedicated wires from the receiver to the doorlock module/relays. I may also be possible to diode isolate the wires to prevent the switches from turning the system on or off. Omega's idea for the arm and disarm inputs are to interface with their GPS tracking units so a person can arm/lock and disarm/unlock remotely by phone or the web, but they can be adapted for other uses.
This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
Chris Luongo
Platinum - Posts: 3,746
Posted: October 15, 2010 at 2:20 PM / IP Logged
Mike M2 wrote:
My understanding is that Avox is coming out with a RS/alarm upgrade...
It should be out now, or at least soon. This morning I met with two Audiovox sales reps and their head of tech support, and got to see the new unit in person.
It comes with two single-button remotes for long-range starting. If you don't need the range, you can leave the single-button remote at home and start the engine using the factory remote (press Lock, Unlock, Lock).
The factory remotes will arm and disarm the alarm system.
The alarm has door trigger, shock sensor, and horn honk. A siren is not included, but I'd imagine the unit probably still has a siren output so you could add your own.
Link:
http://www.lesscoelectronics.com/Pursuit_AS9233ST_Add_On_Remote_Start_System_AS9233_p/as9233st.htm
