2005 cobalt r/s
coolen
Copper - Posts: 121
Posted: November 13, 2010 at 10:12 AM / IP Logged
Good day to all:
I'm going to be doing my first Cobalt (05 MT), and it will be my first one. I want to be as sure as I can. So after reviewing the info on this site, this is what I came up with:
2 Button ProStart 3271
6 PIN MAIN HARNESS:
-Red 12v Batt: At BCM J3 Connector pin D1
-Purple 30A Starter Output:N/A
-Red 12v Batt: Same as above
-Yellow Ign Output:Yellow wire in IGN Harness
5 PIN SECONDARY HARNESS
-Black-Ground
-Purple (Tach Input):White at Coil
-Gray (hood pin): Self explanitory
-Orange Brake Switch Input: Light blue driver's kick panel
-Yellow Park Light Output:Brown Driver's Kick panel
12 Pin Accessory Harness:
The only wires I'm going to use out of here are:
Orange Park brake Input: Light Blue Driver's kick panel (BCM J1 Connector pin 14)
I believe also I will be needing a passlock 2 bypass. Does everything up above look ok??
Platinum - Posts: 7,828
Posted: November 13, 2010 at 11:33 AM / IP Logged
You came to the right place.  Check out this download from one of the members :  https://www.the12volt.com/installbay/file.asp?ID=717   Everything you ever wanted to know about the Cobalt.
