2010 Jeep Wrangler Alarm/Remote Start Wiring
tdmaster
Member - Posts: 7
Posted: June 25, 2011 at 9:13 AM / IP Logged
I have another question about the Main harness ORANGE Wire 500mA Ground When Armed Output. I am not clear from the above notes if this is through a special relay or just straight to a chassis ground?
Platinum - Posts: 7,828
Posted: June 26, 2011 at 6:55 PM / IP Logged
Not sure if I understand the question.  Here is a better description of the GWA output :
H1/12 ORANGE (-) 500mA GROUND WHEN ARMED OUTPUT
This wire supplies a (-)500 mA ground as long as the system is armed. This
output ceases as soon as the system is disarmed. The GWA can be hooked up
to a window module, a voice module or any accessory that requires a ground
when armed.
With a limited 500 mA capacity, it is not a from an internal built in relay.
tdmaster
Member - Posts: 7
Posted: June 26, 2011 at 10:12 PM / IP Logged
when armed.
So, if I understand you correctly, I would connect the BLACK 12v Ground wire from the 516L Programmable Voice System Accessory to this Orange Wire on the 3303 to complete the power circuit on 516L rather than conneting it straight to ground? The 516L also has an Orange output wire, so then that could be used to piggy back another devoce and so on and so forth. Is the correct?
Posted: June 27, 2011 at 5:40 AM / IP Logged
No.  The 516L H1/11 Black Ground Input wire should be connected to chassis ground.  The 516L H1/9 Orange GWA Input wire should be connected to the Viper 3303 H1/12 Orange GWA Output wire.
If you need to connect additional devices to the Viper 3303 H1/12 GWA Output wire, diode isolate and observe the 500 mA current limit.
tdmaster
Member - Posts: 7
Posted: June 27, 2011 at 11:58 AM / IP Logged
Ok, great, thanks for the clarification. I get it now what the Orange wire is for. What you said is how I originally thought it should be but I got confused from an earlier response. This forum is really helpful. Thanks again.
car-tunez
Posted: December 09, 2011 at 1:24 PM / IP Logged
I still need info on the clutch. im installing a CA 5051 MT but need the clutch wire.
id sean
Member - Posts: 22
Posted: December 20, 2011 at 10:11 PM / IP Logged
Just use an ADS-ALCA with an ADS-HRN-CH5 T-Harness and make your life easy
As per Directtechs... The clutch switch is in the engine compartment, on the driver firewall.
Clutch Pedal black (in), yellow/orange (out) - N.O clutch switch, black 3 pin plug, pins 3 and 2
Sean McAuliffe
Sales Rep.
Installation Distributors
