07 camry, remote starter
turtle02909
Posted: December 30, 2010 at 12:23 AM / IP Logged
Hello peeps, I am confuse with the 2nd starter relay diagram. Where 87-12 volts
85-Primary starter wire
86-To car starter's ground out(-)when running
30-2nd starter wire
My problems is #86 to car starter's ground out(-)when running.
Which wire to I connect this to? Is this negative ground from the metal of car? or from the remote starter module that has (-)200ma second starter turn on wire?
resquchas
Copper - Posts: 93
Posted: December 30, 2010 at 3:28 AM / IP Logged
that diagram seems wrong. pins 85, and 86 should be low voltage coil field pins. this seems more correct.but it depends on yor application.
85-   12volt
86-   gwr - from alarm( it goes to the alarm/rs wire not the car or it will always be on. this is the switch wire)
what are you installing. you have to be specific.
The RIGHT way is the ONLY way.
Posted: December 30, 2010 at 4:57 AM / IP Logged
2nd starter wire 200mA to 85.
Ign 1 to 86
30amp fused to 87
Second starter wire from 30
1N4004 diode across 85 and 86, band towards 86.
How many more times does this have to be answered.
Check the archives please.
turtle02909
Posted: December 30, 2010 at 2:29 PM / IP Logged
Where is the tach and rear defrost wires on 07 Camry?
Posted: December 31, 2010 at 6:03 AM / IP Logged
Either rear of tach on instrument panel, engine management pin 9 on your OBD data connector or one of the dissimilar wires at the injectors.
Defrost wire, check from rear window going forwards.
This is where your DMM gets used.
