viper 160xv
pdconway03
Posted: August 19, 2012 at 12:11 AM / IP Logged
i have a viper 160XV system  that was taken out of the car before i bought it and i may think it that when the last owner took it out he may have cut wires he shouldnt have and i want to put it back in but dont know what wires go where does anyone have a wiring diagram for it to hook up to a 99 dodge avenger es v6
One Awesome 99 Avenger ES
lurch228
Silver - Posts: 1,338
Posted: November 11, 2012 at 5:45 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - DODGE / AVENGER / 1999 / Remote Start
[PRINT THIS PAGE]
12volts white + ignition harness
Starter BLACK/ red + ignition harness
Second Starter
Ignition BLACK/ white + ignition harness
Second Ignition
Third Ignition
Accessory blue/black + ignition harness
Second Accessory
Keysense
Power Lock BROWN / white - driver kick, door harness
Power Unlock brown - driver kick, door harness
Notes: To unlock only the driver door on models with keyless entry, use BROWN / blue (-) at the relays behind the radio.
Lock Motor blue/black 5wi driver kick, door harness
Unlock Motor blue/red 5wi driver kick, door harness
Parking Lights+ GREEN / WHITE + driver kick, harness to rear
Parking Lights- GREEN / WHITE - headlight switch
Notes: Found in a gray 20-pin connector.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / green - driver kick, harness to rear
Notes: To avoid the dome light delay use RED / white (-) at the door open indicator at the instrument cluster. The RED / white will also catch the rear hatch.
Dome Supervision use door trigger wire
Trunk/Hatch Pin RED / green - driver kick, harness to rear
Hood Pin blue/black - fuse box
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm GREEN/ YELLOW - driver kick, door harness
Notes: Meter this wire while turning the key in the driver door key cylinder.
Can also use the passenger door key cylinder which is RED / blue (-) in the passenger kick, door harness.
Factory Alarm Disarm GREEN / WHITE - driver kick, door harness
Can also use the passenger door key cylinder which is BROWN / red (-) in the passenger kick, door harness.
Disarm No Unlock see factory alarm disarm
Tachometer white ac instrument cluster or PCM
Notes: The PCM is located on the drivers side of the engine compartment or behind the center of the dash depending on motor.
Wait to start
Brake Wire GREEN / WHITE + brake pedal switch
Parking Brake
Horn Trigger GREEN/ black - horn switch
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
lurch228
Posted: November 11, 2012 at 5:49 AM / IP Logged
Tuesday, September 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
