08 chevy malibu ignition switch
ziggyb222
Silver - Posts: 593
Posted: September 19, 2012 at 2:42 PM / IP Logged
Installed a remote start in this car. Viper 4103 and uncut key in a box for bypass... One issue I had is placing the loop for the transponder bypass. I placed the ring around the outside of the switch but it has made fitting the trim cap tight. There is very little room there. Any ideas where to place the loop? A thinner loop? Or take out the switch and put it on the backside???? Any ideas would be great. Thanks in advance!!!!!
ropuma
Copper - Posts: 102
Posted: September 19, 2012 at 8:26 PM / IP Logged
If the ring has a housing hard plastic cut it out , then use electric tape.
Mike M2
Platinum - Posts: 2,652
Posted: September 20, 2012 at 11:19 AM / IP Logged
What i do is remove the plastic around the ring and twist the coil wires with my finger to hold them together....
Mike M2
Tech Manager
CS Dealer Services
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
