pkall programmed again despite manual
dpav02
Member - Posts: 10
Posted: January 21, 2013 at 9:57 PM / IP Logged
Okay so something strange happened to me today.
I was doing other work to my 4Runner and I disconnected the battery.
Once I got finished I connected the battery.
Then I tried to show off my remote start and my truck just cranked and cranked... I shut it down because I didn't want the starter to burn up...
I tried it again with the key in and it worked. I had a feeling it was the bypass so I checked the connections (they all look good)
Even though the manual says that they can't be programmed again, I figured I'd try it for the hell of it.
Sure enough, I got 10 blinks on the LED... I'm thinking, wth...
Is this common? This PKALL was programmed and working fine until I disconnected the battery. Did that cause it to lose it's mind?!?!
pentavolvo
Copper - Posts: 241
Posted: January 22, 2013 at 6:04 PM / IP Logged
manual states after a battery disconnect must start with key once before remote starting
