'05 yukon w/ 4204v no start/crank
buddholly
Copper - Posts: 244
Posted: November 22, 2013 at 5:13 PM / IP Logged
Try turning engine checking to off and remote start the vehicle..Sounds like you have a bad unit.
dasbogie
Silver - Posts: 514
Posted: November 22, 2013 at 5:29 PM / IP Logged
Are you sure it's not setup for 2 or 3 clicks of the remote start button/activation?
Advanced
smokeman1
Platinum - Posts: 1,589
Posted: November 23, 2013 at 9:24 AM / IP Logged
As dasbogie suggested. It is either one or two pulses for the remote. Menu 3, item 5.
If it is the Two Mode, try pressing and holding the start button until the transmit LED flashes twice, release the button and press it again right away and hold until it flashes once, then let go. It is a bit of a timing thing, so give it a few tries. Or enter the menu set up and change it to one pulse. Does the remote give an error tone and red LED at the function button when start attempt fails?
Thursday, April 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
