2003 Pontiac Sunfire remote starter install
2003sunfire
Posted: January 02, 2016 at 4:45 PM / IP Logged Link to Post Post Reply Quote 2003sunfire
Hi All! First post here but have been a lurker for quite a while and finally joined. Putting a Code Alarm 4054 remote starter in my son's 2003 Pontiac Sunfire along with a PLJX bypass module for the Passlock 2. Got a question on the wire from the Code Alarm box that says to connect to IGNITION #2 wire which this car apparently does NOT have.
Is it OK to just tie into the IGNITION #1 wire along with the other wire that is already added to that wire? Thanks for any help.
chev104275
Gold - Posts: 1,436
Posted: January 02, 2016 at 6:20 PM / IP Logged Link to Post Post Reply Quote chev104275
If you don't need the second ignition wire then Isolate the unused wire and don't connect it to anything.
lectricguy
Copper - Posts: 359
Posted: January 02, 2016 at 6:28 PM / IP Logged Link to Post Post Reply Quote lectricguy
Follow what Chev said. Just use the Ignition 1 wire from the Code Alarm 4054. Connect to the car's ignition wire (Pink in the ignition harness). Just tape the Code Alarm 4054 Ignition 2 wire--no need to use it.
Lectric Guy
2003sunfire
Posted: January 03, 2016 at 7:41 AM / IP Logged Link to Post Post Reply Quote 2003sunfire
So what is the 2nd Ignition wire on the 4054 used for then? It will still function without it?
chev104275
Gold - Posts: 1,436
Posted: January 03, 2016 at 7:55 AM / IP Logged Link to Post Post Reply Quote chev104275
The second ingition is used for different applications. It will function fine without it on your Sunfire
2003sunfire
Posted: January 03, 2016 at 12:59 PM / IP Logged Link to Post Post Reply Quote 2003sunfire
Finished up install today and everything works fine. Thanks!
Monday, September 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
