'13 Tacoma CM7000AS with Blade Al
jdmegcoupe
Copper - Posts: 80
Posted: January 27, 2016 at 3:42 PM / IP Logged Link to Post Post Reply Quote jdmegcoupe
Okay I installed it! Everything is working I think... I ordered a op500 because the one I had keeps saying err01 and I tried it on 3 cars. I need it to program the CM for the EZGO.
jdmegcoupe
Copper - Posts: 80
Posted: January 29, 2016 at 5:25 AM / IP Logged Link to Post Post Reply Quote jdmegcoupe
Okay so I got my op500 and set everything up am I supposed to have both the RFID antenna plugged in to the Control module and the RF-2WSSL antenna for the remotes plugged in?
Platinum - Posts: 7,828
Posted: January 29, 2016 at 5:57 AM / IP Logged Link to Post Post Reply Quote kreg357
The OP-500 will say ERR01 if the controller is in a "doors locked" status.  Just press Unlock on one of the paired remotes and that error goes away.
jdmegcoupe
Copper - Posts: 80
Posted: January 29, 2016 at 6:01 AM / IP Logged Link to Post Post Reply Quote jdmegcoupe
I got that figured out. I am asking if I need to connect both antenna's to the control module for the remotes and the ezgo to work?
Posted: January 29, 2016 at 7:49 AM / IP Logged Link to Post Post Reply Quote kreg357
Haven't used an ES-Go yet but here is the info from the FT7000 Install guide :
Installing The FT-EZGO
STEP 1: Set Option 1-14 to Setting 2, 3 or 4
STEP 2: Connect included Blue 6 Pin (With Ground Wire) to Black 6 Pin to control module. If connecting
to a 4 Pin to 4 Pin antenna, use the included 6 Pin to 4 Pin adapter.
STEP 3: Connect the ground wire from the included 6 Pin to 6 Pin cable to vehicle’s ground. Warning:
Failure to connect this wire WILL result in damage to your FT-EZGO antenna (ANTRFID).
STEP 4: If you are using an additional RF kit the antenna cable will connect to the blue 6 pin connector
on the EZ-GO antenna either directly or using the 6 to 4 pin adapter harness included with the
EZ-GO kit.
STEP 5: Find a spot to mount your ANT-RFID on the windshield. This is recommended for optimum
range. For more specific mounting location information visit us at techfeed.compustar.com
under the Authorized Tech section document titled: “FT-EZGO Recommended Mounting
Locations.”
STEP 6: Program your EZ100-R using the standard remote programming procedure along with any
additional RF Kit remotes to the control module (Maximum 4 Remotes including EZ100-R). You
are now ready to test your FT-EZGO system.
jdmegcoupe
Copper - Posts: 80
Posted: January 29, 2016 at 7:54 AM / IP Logged Link to Post Post Reply Quote jdmegcoupe
Okay so both antenna wires are connected to the CM7000. Then disconnect the cable at the antenna for the 2 way remotes and plug it into the open port on the RFID antenna. Then program the remotes and the ezgo remote to that antenna. Correct?
Posted: January 29, 2016 at 9:01 AM / IP Logged Link to Post Post Reply Quote kreg357
That's not the way I read it.  On the older CM6x00 units, you did not want to plug in two antenna's ( 4 Pin and 6 Pin ) at the same time.  That also included the OP-500 programmer in the 4 Pin port and an antenna on the 6 pin port.  Seems like the EZ-Go plugs into the CM7x00 and the antenna plugs into the EZ-GO's blue 6 pin port.  But like I said, I haven't used an EZ-GO yet...
