2012 Nissan Juke pts manual no start
sand33p_sidhu
Member - Posts: 25
Posted: January 19, 2017 at 3:11 PM / IP Logged Link to Post Post Reply Quote sand33p_sidhu
hey guys,
installed a compustar CM7200 in a 2012 Nissan Juke PTS manual trans. Everything work except it doesn't remote start remote start the vehicle unless if I have the clutch pressed down. I have the clutch bypass by a relay. What could be the problem? It goes in reservation mode after existing the vehicle. When attempted to remote start the vehicle, ignition comes on but doesn't start. Is there another safety switch somewhere that I am maybe missing? Any help would be much appreciated,
Thank You
Regards,
Platinum - Posts: 7,827
Posted: January 19, 2017 at 4:03 PM / IP Logged Link to Post Post Reply Quote kreg357
Actually, you have to open one wire and apply a (+) to another wire and the clutch pedal.
Apply (+) 12V Starter signal to the Brown wire at the clutch pedal interlock switch and open the Grey wire at the Cruise
control switch with a GWR signal. You will need a relay for the Grey wire.
sand33p_sidhu
Member - Posts: 25
Posted: January 19, 2017 at 9:25 PM / IP Logged Link to Post Post Reply Quote sand33p_sidhu
kreg357 - thanks for the reply, i have the start wire hooked up to the brown wire at the clutch switch and grey wire at the cruise switch is split open and wired thru a relay! still doesnt wanna work, could there be another switch under the hood somewhere ??
jap1975
Member - Posts: 12
Posted: January 20, 2017 at 5:07 AM / IP Logged Link to Post Post Reply Quote jap1975
check the hood switch, also check hand break switch both switches give negative trigger to the alarm module. some times hood switch becomes corrosive due to exposure to water and other environmmental factors. If it is faulty replace it with new and also see good contact to car metal body ( the paint surface should be scratched) is available when hood is opened. Like wise when you press and depress the clutch check the switch connections for the results.
Have a 12 volt bulb tester with you to check the switches. Preferably a multimeter is good. If after testing noresult is found assume the switch is the culprit. replace it and check further. Hope this helps.
Hi doing myself will bring great happiness and satisfaction even at the cost of time.
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
